Proof about countable base of topological space
sunjin09
Prove that if a topological space has a countable base, then all bases contain a subset which is a countable base
A base is a subset of the topological space such that all open sets can be constructed from unions and finite intersections of open sets from the base
I'm only a few pages into this chapter, all I learned so far is arbitrary union and finite intersection are closed operations. I have no clue how to construct a countable subset from an arbitrary base, not to mention that it
must be a base by itself. Any help is appreciated
By my definitions, that's a sub-base. A base is a collection of open sets such that every open set is a union of members of that collection. Check your book to make sure that it uses this definition.
sunjin09 said:
I have no clue how to construct a countable subset from an arbitrary base, not to mention that it must be a base by itself.
You don't have to specify what sets are members of this countable subset. You just have to show that such a set exists. I don't immediately see the solution to the problem. I will take a few minutes to think about it.
Thank you for correcting the mistake in the definition about the base, it is indeed only unions are allowed. As I researched on the internet, such a space is called second countable space, and the property I'm going to prove is well known, although the proof is not easy to understand. I'll outline below:
Let B=\{B_{\alpha}|\alpha\in A\} be an arbitrary base, and C=\{C_i|i\in I\} the countable base, then for each C_i, the set of sets S_i=\{B_\alpha|\exists j\in I\,{\rm s.t.}\,C_j\subset B_\alpha\subset C_i\} turn out to be countable, if for each j so that such B_\alpha exists, choose only one of such B_\alpha's. The union of the sets in S_i is C_i(needs some constructive proof), therefore the union of countable sets S_i for all i's turns out to be a countable base.
I wasn't able to make any progress with your problem yesterday, but I only spent 15 minutes or so on it.
Isn't the set S_i, as you have defined it, equal to ##\{B_\alpha\in B|B_\alpha\subset C_i\}##? This is what I'm thinking:
Let i be an arbitrary member of I. Since C_i is a member of a base, it's open. Since B is a base, this implies that there's a subset ##A_i\subset A## such that ##C_i=\bigcup_{\alpha\in A_i}B_\alpha##. The ##B_\alpha## with ##\alpha\in A_i## must be subsets of C_i, so this ensures that the set S_i is non-empty.
Let ##\alpha## be an arbitrary member of ##A_i##. Since ##B_\alpha## is a member of a base, it's open. Since C is a base, this implies that there's a subset ##I_\alpha\subset I## such that ##B_\alpha=\bigcup_{j\in I_\alpha} C_j##. The C_j with ##j\in I_\alpha## must be subsets of ##B_\alpha##, so there's always a C_j (with ##j\in I_\alpha##) such that ##C_j\subset B_\alpha\subset C_i##.
I don't see how to prove that each S_i are countable. That would be a surprising result actually. I would expect those sets to not be countable. But maybe you can do what you're suggesting at the end anyway: For each i in I, choose an ##\alpha\in A## such that ##B_\alpha\subset C_i##. Then maybe you can prove that the set of all ##B_\alpha## chosen this way is a countable base. (I haven't tried that myself). It's clearly countable, because of how the sets were chosen.
It is indeed how to construct S_i that is the trickiest part, for each x in C_i, there exist a B_α containing x that is a subset of C_i; since B_α is also the union of C's, there is a C_j containing x that is a subset of B_α, keep this B_α, and change to another x and do the same thing, if the resultant C_j is different, keep the B_α, otherwise do not keep the B_α; after exhausting all the x's in C_i, one obtains at most countably many B_α's corresponding to the C_j's, and these B_α's contain all the points x in C_i, and they are all subsets of C_i as well, therefore their union is C_i.
By merely reading the proof took me hours to convince myself, and it helps to try to rephrase it in my own language.
Let \mathcal{B} be your arbitrary basis. The easiest proof of this is to take a countable basis \mathcal{A} and to look at the collection
\mathcal{C}=\{(A,A^\prime)\in \mathcal{A}\times \mathcal{A}~\vert~\exists B\in \mathcal{B}:~A\subseteq B\subseteq A^\prime\}
This is countable (why?).
Now, find a map \mathcal{C}\rightarrow \mathcal{B}.
This is certainly a much clearer way of thinking, C is countable because it's a subset of the Cartesian product of two countable sets. The mapping f: C → B is obvious by definition, and is non-unique. Any one of such mappings f should have that Im(f) is a countable base, since for any fixed A' and all pairs (A'',A') where A'' is a subset of A', the union of A''s is A' since A is a base; and f(A'',A') exists, since B is a base; the union of f(A'',A') is also A', since it includes A' and is simultaneously included in A'. Therefore Im(f) is a base, since any A' is a union of Im(f) elements.
