Finding Modes of Vibration in ANSYS
  • Thread starter Thread starter adpr02
    Modes Vibration
To determine the important modes of vibration in ANSYS, focus on the lower frequency modes, as they require less energy to excite compared to higher frequencies. Each mode has an associated natural frequency, and the modes near the excitation frequency are particularly significant. The first nine modes may be below the forcing frequency, but the tenth mode aligns closely with it, making it crucial for analysis. Additionally, modes where the structure exhibits significant movement at the force application point are vital, as greater movement allows for more effective excitation. In transient situations, all lower modes are important, while in steady-state conditions, the focus shifts to those modes near the excitation frequency.
adpr02
Hi,
I'm playing around with ANSYS to find the modes of vibration of a structure. How do I know which are the most important modes? I understand that there are infinite modes of vibration - getting higher and higher in frequency.
I'm guessing that it has something to do with the effective mass of each mode versus the total mass.
Also, when people say "Natural Frequency," which mode does that frequency belong to?
Cheers
There is a "natural frequency" associated with each mode of vibration. For most purposes, the lower frequency modes will be the important modes, because it takes more and more energy to excite the higher frequency modes.
Ok. How do I know how many of the lower modes are important?
The reason I ask is because the first 9 are well below forcing frequency. 10th mode is pretty much bang on the forcing frequency.
If your excitation force is a sine wave at a fixed frequency, the important modes are likely to be the ones close to that frequency. It doesn't matter whether that is the first or the 100th mode.
Actually you can improve on that statement by saying the important modes are also those where the structure moves a lot at the point where the force is acting, because theo more the structure can move, the more work force can do to excite that mode (work = force x distance).
In a transient situation, all of the lower modes are important. In steady state, it is more as AlephZero has described. Remember also that an excitation acting at a nodal point of a particular mode cannot excite that mode, no matter what the extent of frequency alignment.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
