Locus of light falling on a plane surface
When light from a lamp falls on a wall through a circular opening, it creates a hyperbola due to the intersection of a cone with the plane of the wall. The angle of the light affects the shape of the projection; tilting the shade can transform the hyperbola into a parabola or ellipse at critical angles. Conic sections, including hyperbolas, arise from the intersection of a cone with a plane and are described by quadratic equations. Lenses, which have spherical surfaces, may also produce hyperbolic patterns due to their geometric properties. The discussion highlights the relationship between light behavior and conic sections, illustrating the mathematical principles at play.
hale2bopp
When there is a lamp on a wall and the light from the lamp falls on the wall, we notice that the shape formed by the light is a hyperbola. I would like to know what the explanation for this is.
Also, when you have a convex lens and you kee it flat on a horizontal surface, and sunlight falls at an angle on to the lens, you can see a curve of light on the surface that looks to me very much like a hyperbola.
A hyperbola is the locus of a point moving such that the difference of its distances from two fixed points is constant. That makes sense when you're wondering why the locus of an interference pattern should be a hyperbola, because the path difference is constant. But I can't relate this to the phenomenon of light falling on a wall, or the lens thing.
Thanks in advance!
Science news on Phys.org
I assume the light has a shade with a circular opening.
The light passing through the opening projects a cone.
The intersection of a cone with a plane produces various "conic sections" depending on the angle.
If the axis of the shade's opening is parallel to the wall then you will see a hyperbola.
If you tilt the shade down so as to direct the light more fully onto the wall, at a critical angle (i.e. when the light falling furthest from the wall is going straight down) it becomes a parabola.
Tilt a fraction more and you have an ellipse.
In general, conic sections are the curves that satisfy quadratic equations. The locus of intersection of a cone with a plane will also satisfy a quadratic equation. And the locus of a point that's always further from one fixed point than another by a constant amount is also a quadratic equation.
Lenses are ground with spherical surfaces - more quadratics. So it wouldn't surprise me if that also gives you hyperbolae, though I haven't checked it in detail.
Btw, have you noticed the pattern light from a point source forms at the bottom of a cylindrical cup? No conic this time.
Thank you so much! This explained things perfectly. I will try to check out the light source at the bottom of a spherical cup. :)
Actually I said cylindrical, the usual shape for a mug, and the light source is outside the mug. It's the pattern produced at the bottom that's interesting.
