Differential Equations and Circuits
Understanding the arrangement of variables in differential equations for LR circuits is crucial for proper integration. In the equation L(dI/dt) + RI = V, the terms must be organized to maintain the relationships between the variables during integration. The variable I is grouped with dI because they both change together, while V must remain with IR to ensure the integrity of the equation. The placement of L, V, and R can vary depending on whether they are constants or functions of time, which affects how they are treated in the integration process. Properly arranging these terms is essential for accurate results in solving circuit equations.
nikki__10234
So, I'm learning how to solve LR, RC, LC etc. types of circuits using differential equations. I understand how to do the math with differential equations, but I am confused as to why the variables are split in the way they are.
For example, for an LR circuit you have the equation
L(dI/dt)+RI=V
and then the book integrates both sides:
∫(dI/(V-IR))=∫(dt/L)
and so on...
It is justified to group the I term with the dI, but I don't understand why the L, V, and R terms are placed as they are? Could you get the same result if they were not arranged in this way since the integral is not being taken in terms of V, R or L?
welcome to pf!
hi nikki! welcome to pf! :smile:
nikki__10234 said:
L(dI/dt)+RI=V
and so on...
the V has to stay with the IR …
can you see any way of getting the IR over onto the LHS (with the dI), without the V coming with it?​
but the L could go either side
L(dI/dt)+RI=V
and so on...
The only requirement is that any variables which actually vary in the range of integration stay inside an integral, but it will help if it varies as a function of the variable of integration with which it is placed.
E.g. if L = L(t) then it would best be placed in the integral .dt as above, whereas if R is a constant then you could just as easily write
∫(dI/(V/R-I))=R∫(dt/L)
OTOH, if V = V(t) it's going to get tricky ;-).
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
