Need to find the Ricci scalar curvature of this metric
chinared
Need to find the Ricci scalar curvature of this metric:
ds2 = e2a(z)(dx2 + dy2) + dz2 − e2b(z)dt2I tried to find the solution, but failed to pass the calculation of Riemann curvature tensor:
<The Christoffel connection> Here a'(z) denotes the first derivative of a(z) respect to z.
\Gamma\stackrel{x}{xz}=\Gamma\stackrel{x}{zx}=a'(z)
\Gamma\stackrel{y}{yz}=\Gamma\stackrel{y}{zy}=a'(z)
\Gamma\stackrel{z}{tt}=b'(z)e2b(z)
\Gamma\stackrel{z}{xx}=\Gamma\stackrel{z}{yy}=-a'(z)e2a(z)
\Gamma\stackrel{t}{tz}=\Gamma\stackrel{t}{zt}=b'(z)
\Gamma\stackrel{}{either}=0
<The Riemann curvature tensor>
R\stackrel{x}{zxz}=R\stackrel{y}{zyz}=-a''(z)-[a'(z)]2
R\stackrel{z}{tzt}=b''(z)+[b'(z)]2
I tried to find the Ricci scalar curvature(R) from current result, but it gave a function depend on z. Is there any problem in my calculation?
Thanks for answering this question~!
I didn't check your calculation, but why do you think the Ricci scalar shouldn't depend on z?
I got the same for the Christoffel symbols, but I got a lot more non-zero elements for the Riemann curvature tensor.
Sorry for that I did not write down the other non-zero terms of Riemann curvature tensor which can be deduced by symmetry and anti-symmetry properties.
However, I still have a contradiction that
Rt _ztz-b''(z)-[b'(z)]2
but
Rz_tzt=[b''(z)+[b'(z)]2]e2b(z)
Did you also get the same result?
I get
Rztzt = -[b''(z)+[b'(z)]2]e2b(z)
Thank you, I will check my result again
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
