Is there any circuit for generating Gaussian Noise with
A circuit for generating Gaussian noise can be achieved using a low leakage vacuum photodiode in a dark enclosure, where the dark current produces a Poisson distribution of electrons. By controlling the dark current, one can manipulate the mean and variance of the noise generated. Increasing the current leads to Gaussian distributions, allowing for flexibility in noise characteristics. Additionally, using a light source with neutral density filters can further adjust the electron count. Shot noise from solid-state PIN diodes is also a viable method for generating Gaussian noise.
paawansharmas
Is there any circuit for generating Gaussian Noise with a mean and variance.
we should have control to change mean as well as variance accordingly.
thanks.
One method is to use a very low leakage vacuum photodiode (with anode and cathode on opposite ends of the glass envelope) in a completely dark enclosure, and look at the dark current. If you have a 1 femptoamp dark current, that is equivalent to 6250 electrons per second. If you look at the number of electrons per millisecond, it should be a Poisson distribution with an average of 6.2 electrons. Increasing the current will produce Gaussian distributions. Using a light source and neutral density filters, you can get any number of electrons you want. Shot noise in solid state PIN diodes also are good sources.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
