Acceleration due to gravity in a galaxy?
The discussion focuses on calculating the acceleration due to gravity at the periphery of a galaxy, emphasizing the need for three key variables: distance from the galaxy center, total mass within that radius, and the gravitational constant. It suggests using Newton's law of gravity for calculations and provides a formula to estimate gravitational acceleration using the mass of the galaxy and its radius. For example, with a galaxy mass of approximately 700 billion solar masses and a radius of about 15,000 parsecs, the estimated acceleration is around 0.4 nanometers per second squared. The conversation also touches on the simplicity of the calculation compared to more complex equations like Einstein’s Field Equation. Understanding these calculations can provide insights into the gravitational dynamics of galaxies.
Bjarne
How strong is acceleration due to gravity ?
For example at the periphery at a galaxy ?
Astronomy news on Phys.org
To determine the acceleration due to gravity at the periphery of a galaxy, you need to know three numbers. The first is the distance from the galaxy centre where your acceleration is to be calculated (the radius). The second is the total mass of the galaxy contained with that radius. The third is the gravitational constant, G.
Lastly, you will need to learn about Newton's law of gravity (the wikipedia article is suffucient). With the above three numbers, some knowledge of how gravity works and a little bit of calculating, you should be able to work the numbers out yourself.
Put this into google "G*(mass of sun)/(1 AU)^2"
without the quotes
The google calculator will tell you the accel due to sun's mass at the Earth's usual distance of 1 AU.The distance from center to apparent edge is sometimes estimated
about 15,000 parsecs. The mass of our galaxy within that radius has been put at 700 billion solar masses. Try this in the google search window, without the quotes:
"G*(700*10^9 mass of sun)/(15 kpc)^2"
I think you will get around 0.4 nanometer per second per second.
Thank's
PS..
1.) I thought the equation was more complicated (Einstein’s Field Equation). But I assume GM/r^2 can be used as a rough estimation (?).
2.) I thought there are “only" 200 stars” in a typical galaxy (not 700 ?)
3.) 15,000 parsecs = 4,62e20 Meter (50.000 LY )
700e9*2e30*6,67E-11/4,62e20^2= 4,37e-10 M^2
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
