How Do You Calculate Rocket Exhaust Velocity and Total Acceleration at Liftoff?
  • Thread starter Thread starter AbigailM
    Rocket
AbigailM
Still preparing for a classical prelim. Not sure if my solution is correct. Any help is more than appreciated.
According to specifications, the five Saturn V booster engines collectively supplied a liftoff thrust of 34 \times10^{6}N. The specific impulse was 2580 N-s/kg. The initial mass of the rocket was 3.0\times 10^{6}kg. Given these specifications, what was the exhaust velocity, and what was the total acceleration including the acceleration of gravity, felt by the astronauts on liftoff (in g's)?
*The specific impulse is the ratio of the thrust to the rate of consumption of propellant. It is nearly constant.
v_{ex}=I_{sp}g \hspace{5 mm}\dot{m}=\frac{F_{th}}{I_{sp}}
a(t)=\frac{\dot{m}v_{ex}}{m_{0}-\dot{m}t}-g=\frac{F_{th}g}{m_{0}-\dot{m}t}-g
where m(t)=m_{0}-\dot{m}t \hspace{5 mm}m(t)a(t)=\dot{m}v_{ex}
\dot{m}=\frac{3400\times 10^{4}N}{2580\frac{N.s}{kg}}=1.3\times 10^{4}\frac{kg}{s}
a(t)=\frac{3400\times 10^{4}N}{3.0\times 10^{6}-1.3\times10^{4}\frac{kg}{s}t}g -g
Note: Something that confused me was that that the I_{sp} given is in m/s.
Thanks for the help.
When specific impulse is given in unit m/s (which is equal to N-s/kg) it really represent exhaust velocity, as related by your first equation. That is, the exhaust velocity of 2580 m/s corresponds to a specific impulse of 263 s.
Notice, that your second equation is not correct (it misses a "g", or, you should replace Isp with Vex). However, since you actually used Vex in your calculation you ended up with the correct result for the mass rate.
The expression for the rockets acceleration looks correct, but if you want a(t) to represent how much acceleration the astronauts feel (including gravity) you want consider what a(t) should be equal if the rocket has zero acceleration. Also, as I read the last question, it seems you only need to calculate the value of a(0), that is, the felt acceleration at lift-off.
As always Filip thanks for the help.
Yep it does say a(0) lol, hope I don't miss something like that on an exam.
There ended up being an error in my a(t) equation, because I should have used v_{ex}=I_{sp}\frac{g}{g}. When I use that and crunch out the liftoff acceleration ignoring gravity, I get roughly 1.15g's, which is close to the 1.13g's experimental.
And thanks for the gravity hint, I should have put + instead of -. The acceleration vector on the crew is in the same direction as gravity, even though the rocket's acceleration vector is upwards. Newton's third law :(.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
