How exctly the higgs field originted after the big bang?
The discussion centers on the origins of the Higgs field in relation to the Big Bang, with participants debating whether the Higgs field existed prior to this event. It is suggested that the Higgs field has a potential energy structure that changes with temperature, impacting mass acquisition as the universe cools. The concept of phase transitions, particularly electroweak and QCD transitions, is highlighted as crucial to understanding the Higgs mechanism. Participants also explore the idea of tachyonic fields and spontaneous symmetry breaking, emphasizing that the Higgs field may not have existed before the Big Bang. The conversation concludes with the distinction between the Higgs field and the inflaton field, noting their differing energy scales.
Abersman
i know that they are trying to recreate the higgs boson at CERN LHC, but talking about when the big bang happened, how was the higgs field suppose to happen?
Astronomy news on Phys.org
I was under the impression that the higgs field always existed, and it was only once the energy levels of the universe were reduced below a certain point that things acquired mass.
Phase Transitions in the Early Universe - Electroweak and QCD Transitions
The Higgs-particle field has a potential energy that's shaped like a bowl with a hump in the middle. When the temperature is high enough to make Higgs particles (T >~ mH ~ 125 GeV), then the resulting Higgs-field fluctuations compensate for that central hump, and above about 300 GeV, make it disappear altogether.
That means that the Higgs field stops having a nonzero average value at about then, ending the low-energy Higgs mechanism.
[hep-ph/9702324] Finite temperature effects on the neutrino decoupling in the early Universe - thermal fluctuations create effective masses for every particle, with mass values about (interaction strength) * T.
The descriptions I've seen are similar to the prior post.
My understanding is the Higgs field are associated with particular types of vacuums. I have never heard it proposed that before the big bang there existed a Higgs field everywhere. Such a Higgs mechanism
involving different possible 'vacua' is..an essential ingredient of inflation
according to Roger Penrose in THE ROAD TO REALITY, 28.1.
I think the Higgs field is a manual input to inflation...and the standard model of particle physics...just like the inflation which originated with Guth is a manual input...a mathematical tool used to solve some issues and produce some observational predictions...I also checked several sections of Wikipeida...via "Higgs mechanism" and ended up here:
But if they describe the origin of the field I missed it: They say the Higgs boson is a tachyon...but not faster than light...
Tachyonic fields play a very important role in modern physics.
Perhaps the most famous example of a tachyon is the Higgs boson of the Standard model of particle physics. In its uncondensed phase, the Higgs field has a negative mass squared, and is therefore a tachyon.
The phenomenon of spontaneous symmetry breaking, which is closely related to tachyon condensation, plays a central part in many aspects of theoretical physics, including the Ginzburg–Landau and BCS theories of superconductivity.
Other examples include the inflaton field in certain models of cosmic inflation (such as new inflation[8][9]), and the tachyon of bosonic string theory
The link to http://en.wikipedia.org/wiki/Tachyon_condensation describes how a Higgs like scalar field produces particles...edit: here is a related discussion:
https://www.physicsforums.com/showthread.php?t=621236
and I am reminded from it that the Higgs field is associated with a non zero expectation vacuum...hence I believe that suggests the Higgs field did NOT exist before the BB...maybe an 'expert' will clarify for us.
The field that makes inflation is sometimes called the inflaton (no i), and it's like a spin-0 one.
However, the inflaton cannot be the Higgs particle, because of the great difference in energy scales:
Higgs: ~ 300 GeV
inflaton: ~ 1015 GeV
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
