Python Why does Python 3's print(1!=0==0) return 'True'?
  • Thread starter Thread starter Bipolarity
    Python
The expression print(1!=0==0) evaluates to 'True' due to Python's comparison chaining feature, which allows multiple comparisons to be evaluated in a single expression. The evaluation begins from the left, first determining if 1 is not equal to 0, which is True, and then checking if that result is equal to 0, which is False. Thus, the overall expression evaluates to True. The discussion emphasizes the importance of using parentheses to clarify the order of operations and avoid ambiguity. It also highlights that while chaining comparisons can be useful, it can lead to different behaviors in function calls, particularly regarding how many times a function is executed, which is crucial when side effects are involved.
Bipolarity
print(1!=0==0) seems to print the value 'True'. I'm trying to understand why.
Does it first evaluate (1!=0) ?
Or does it first evaluate (0==0) ?
Or does it separate them into (1!=0)^(0==0) ?
I appreciate all help.
BiP
Technology news on Phys.org
Not sure but I think it would use the left to right rule since != and == would have the same precedence as operators.
It's best to write code without an ambiguity like this by explicitly using parenthesis to order the sequence of operations.
That's what it does. There's some python comparison chaining magic going on here to enable expressions such as 0<x<1 to mean x is between 0 and 1 -- just like one would write in math. That you can use it for 1!=0==0 is a side effect of this magic.
Thanks for the tip on the 0<x<1 syntax DH. That's useful to know. :)
Though surely it's equivalent to (1!=0) and (0==0), rather than xor.
Correct. I read the ^ as the mathematical shorthand for boolean and, which is not the case.It's not quite equivalent to (1!=0) and (0==0). There is a subtle difference. Consider
self.inbounds = 0 < self.some_function() < 1
This will call self.some_function() once and only once. Now let's rewrite this expression as
self.inbounds = (0 < self.some_function()) and (self.some_function() < 1)
With this rewrite, self.some_function() will be called once if the result from the first call is non-positive, twice if it is positive. Calling the function sometimes once, sometimes twice, can be deleterious if the function has side effects.
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
