Partial differentiation: thermodynamic relations
unscientific
This question is about entropy of magnetic salts. I got up to the point of finding H1, the final applied field.
But instead of doing integration I used this:
dS = (∂S/∂H)*dH
= (M0/4α)(ln 4)2
I removed the negative sign because they wanted decrease in S.
I know integration is the sure-fire way to get Sinitial - Sfinal but why is this method wrong? Is it because this method is only an approximation?
dS = (∂S/∂H)*dH
= (M0/4α)(ln 4)2 I removed the negative sign because they wanted decrease in S.I know integration is the sure-fire way to get Sinitial - Sfinal but why is this method wrong? Is it because this method is only an approximation?
I'm not sure exactly what you'e done here. dH is a differential, so it makes no sense to say that \left( \frac{ \partial S}{ \partial H } \right)_{T} dH = \frac{M_0}{4\alpha}\ln(4)^2.
If you Taylor expand S(H, T) around the point H=0, holding T constant. then to first order you get
S(H_1, T) \approx \left. \left. \left( \frac{ \partial S}{ \partial H } \right)_{T} \right. \right|_{H=H_1} \cdot (H_1-0)= \frac{M_0}{4\alpha}\ln(4)^2
but that is only a first order approximation.
What I meant was:
dS = (∂S/∂H)*dH + (∂S/∂T)dT
But since dT = 0 since T is kept constant,
dS = (∂S/∂H)*dH
unscientific said:
What I meant was:
dS = (∂S/∂H)*dH
That's completely correct, but how did you get from that to (M0/4α)(ln 4)2?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
