What should I know about winding a motor's coil?
  • Thread starter Thread starter sanfadilan
    Motor Winding
To wind a motor's coil effectively, it's essential to determine whether the motor is AC or DC, select the appropriate gauge of wire, and understand the required amperage and voltage. The number of turns in the coil directly influences the induced voltage, which can be calculated using Faraday's law. Additionally, the power of the motor is influenced by the coil's resistance, and the magnetic force can be measured to ensure compatibility with the motor's design. Resources for further learning include a detailed article on motor windings and calculations available on the author's website. Understanding these fundamentals will aid in successfully winding a motor coil.
sanfadilan
Motor winding problem please help me..?
if I got a armeture of a motor without a coil and ask to wind the coil what should I know to do this
and how to know whether,
* it is a AC/DC motor
* what gage of coil it should be
* what is the ampere and voltage
* how many turns should i wind in a one part of the armeture
* and how should I wind it
* how to know the power of the motor
* how to measure the magnetic force of the permanent magnet
* are the forces of both electric and permanent magnets same ?
if you know anything about these please answer me...
describe me in simple english
if you know any link to learn them please give me them also
The induced voltage depends on the diameter (area) of the coil and the number of turns of the coil.
The power is determined as well by the resistance of the coil.
Faraday's law will give you the induced emf in the coil:
V= (dΦ/dt)= NA(dB/dt)
N=the number of turns in the coil
A=area
B is the magnetic field
dt=time
ΦB is the magnetic flux in Webers or Tesla ( Tesla is the SI unit)
The current will be I = V/R. OR:
E=N((dΦB)/dt)
A complete discussion on the topic of windings, power output
and an example of an actual motor is on my website:
http://www.watchman2012.com/articles/spout24.shtml
The page is quite popular among those building wind turbines to calculate the output of
ANY given motor they build, to see if what they are building is adequate.
I worked out the maths with a real physicist over a two month collaboration period
and quite pleased at the resulting paper. (the vector calculus was a bear !)
the first of it's kind information on the web.
and it is all boiled down to one simple plug-in formula !
I started from the beginning with particle physics thru faraday etc
to have a complete understanding, it was FUN, then again if I was a spice girl i'd be geeky-spice ;)
enjoy
-Watchman
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
