Eagle Circuit Design: Free Schematic Program
  • Thread starter Thread starter Tom McCurdy
    Program Schematic
Eagle is recognized as a powerful free schematic and board layout program, though it lacks simulation capabilities. Users appreciate its ability to link schematics and layouts for easy updates, but some find it necessary to create custom library components for specific modules. Comparisons with PSpice highlight that while PSpice offers extensive simulation features, it may not accommodate certain unique components. The discussion also touches on the challenges of building specialized circuits, particularly in radio transceiver design. Overall, Eagle's free availability and user-friendly design make it a popular choice for hobbyists, despite its limitations in simulation.
Tom McCurdy
Does anyone here use Eagle to design circuits... its seems really powerfull, but I am still trying to work out some minor details
I used it last year for a while and still have the program and files that I was working on. I have version 4.11. It was a free download. For a free program it's extremely powerful and more than sufficient for my needs.
I don't know whether I can help you or not. What details do you need to work out?
Sorry cannot answer your question but I am interested how it may compare to PSpice
which I have used for eons for schematic capture and simulation if you are familiar with that -- Thanks Ray.
I'm not familiar with PSpice but I did go to the OrCAD website to look at it. It sounds like it does quite a bit. Is that a free download also? I saw free patches and upgrades, but I didn't see anywhere to download the actual program for free.
The Eagle is a very simple and primitive schematic and board layout program. It doesn't do any simulations at all (at least not that I'm aware of). I don't think that feature would help me much anyway because I also use rare modules that are never incorporated into simulators anyway!
Like right now I'm building a digital radio transceiver around a couple of Reynolds modules,…
http://www.rentron.com/remote_control/RWS-434.htm
http://www.rentron.com/remote_control/TWS-434.htm
I had to make my own library components in both the schematic and the components libraries for these modules. What would a simulator do with these modules?
Actually it would be nice if I could run a simulator on these circuits that I'm creating. I'm basically building them live as I go and testing them real-time. Here's a link to the Eagle schematic that I created for my little transceiver board:
http://www.csonline.net/designer/
I created this schematic using Eagle, and most of the symbols were hand-created by me. I only create small special-purpose boards so I don't mind creating my own symbols. The main thing I like about Eagle is that it was FREE. :biggrin:
It also links the PCboard layout to the schematic for easy updating and editing. But it has absolutely no simulation capabilities.
But would PSpice really help me in that regard anyhow? It certainly can't simulate the radio connection. It probably also wouldn't recognize the Reynolds modules.
By the way, where's Tom? Did he have a question, or did he get all the details worked out?
PSice can be obtained free as a demo or 'student' version which is limited , but I have lost the site for the moment. In it's full version it has a lot of module models -- reynolds I do not know -- I use it at the transistor level where it excells --- but it can handle mixed analogue and digital and being from Orcad it can now handle or link to layout work. Simulation can be in the frequency domain or time , and the transistor library can be obtained from Philips which is awsome with up to 50GHz devices.
Just a personal note I have always stayed away from AM , and infinitely prefer FM
as the modular receivers are very sensitive and narrow band but at 400 Mhz you need surface mount technology and physically small components so it's a pain for the experimenter-- best of luck Ray.
PS the last transeiver simulator that I saw was in Calgary University in Canada with an installation of some 2M$ , which could simulate not only the whole circuitry ( analgue and digital ) at 1 Ghz but also simulate all the propogation characteriscs as well -- this was for wide band (20Mhz) psuedo random sequence modulation aiming at 100 Mbit data rate in the 20M channel.
some fun !
I agree about the FM vs. AM, but I'm working under cost restraints here, and the AM should suffice for my purposes.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
