Basic geometry question re isosceles triangles
  • Thread starter Thread starter michaelamarti
    Geometry Triangles
The discussion revolves around the use of the small angle approximation in deriving the differential area element in polar coordinates, specifically in the context of isosceles triangles. The author of "Mathematical Methods for Scientists and Engineers" claims the base of the triangle is rΔθ, while the questioner suggests it should be r(sin(Δθ)). The responses clarify that the approximation sin(Δθ) ≈ Δθ is valid for small angles, leading to the conclusion that rΔθ is an acceptable simplification. Additionally, the discussion touches on the geometric interpretation of the area as part of a circular sector, where the arc length is also expressed as rΔθ. The conversation highlights the application of linear approximations in integration theory, emphasizing their accuracy as the partition becomes finer.
michaelamarti
I am reading "Mathematical Methods for Scientists and Engineers" by Donald McQuarrie. In his discussion of polar coordinates, he uses a geometric argument to derive the differential area element, which is of course rdrdθ. He shows an isosceles triangle whose two equal sides are r, and the angle that they make at the top of the triangle is delta(theta), where delta(theta) is small. From this he says it follows that the base of the triangle is equal to
r(delta)(theta).
However, I can not find this in my geometry book. Shouldn't the base be something like
r(sin)(delta(theta))?
I also ran into this same problem in an astrophysics book where the author used the very same argument for deriving the formula for the distance to a star by determining the parallax angle.
In both cases, are the authors using the "small angle approximation" that sin(theta) = theta?
Sorry to ask such a basic geometry question. I'm 61 years old, and I don't remember my high school geometry that well.
Mathematics news on Phys.org
Yes, they are using the small angle approximation that you refer to. Actually, the exact value would be 2rsin(delta/2), which comes out to r *delta using that approximation. These linear approximations are valid in integration theory because of the nature of the integral. It is defined as a limit of a sum as you partition the region of integration into small pieces. So on each small piece, the linear approximation is quite accurate. In the limit, (as the partition of the region gets finer and finer) the linear approximation is exactly correct.
r(delta)(theta).
What you have written doesn't make much sense - sin by itself is as meaningful as √ by itself.
I don't have the book you cite, but I'm going to guess that he's approximating the area of part of a circular sector. This region is four-sided, with two of the sides being curved.
If you take what you're calling an isosceles triangle (actually it's a sector of a circle), and extend the two rays by Δr, you get the four-sided figure. It's roughly a rectangle, where one dimension is Δr and the other is rΔθ. If you multiply those, you get rΔθΔr, which is the same as rΔrΔθ.
The part that might be confusing you is the rΔθ. This is the length of the arc of a circle of radius r, that is subtended by an angle of measure Δθ. If the circle's radius is 1, the arc length will be 1Δθ or Δθ. If the circle's radius is 2, the arc length will be 2Δθ. In general, if the radius is r, the arc length is rΔθ.
Probably.
It might not have been covered. When I took geometry (a few years before you did), most of the time we studied triangles, and didn't do much with other geometric figures.
Thank you.
Holiday Greetings!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
