Therefore, since P(A) = 0, we have convergence in probability.
The discussion centers on the convergence of random variables and their estimates, particularly regarding the maximum of a sample as an estimator for the parameter θ. Participants express confusion about the reliability of using the sample maximum as an estimate, acknowledging that it may not accurately reflect θ due to the randomness of samples. The expected value of Y_n is debated, with clarification that E(Y_n) converges to θ, implying that the maximum Y_n also approaches θ. It is emphasized that while the maximum is a good estimate, it can still be incorrect, and the probability of it being less than θ approaches zero as the sample size increases. Overall, the conversation highlights the complexities of probability theory and the relationship between random variables and their expected values.
Artusartos
I was a bit confused with the pages that I attached...
1) "An intuitive estimate of \theta is the maximum of the sample". But we are only taking random samples, so even the maximum might be far from \theta, right?
2) I don't understand how E(Y_n) = (n/(n+1))\theta. I thought that E(Y_n) = (Y_n)*pdf = (Y_n)(\frac{nt^n-1}{\theta^n}).
3) "Further, based on the cdf of Y_n, it is easily seen that Y_n \rightarrow \theta". Does that mean that E(Y_n) converges to theta, so Y_n must also converge to theta?Thank you in advance
Stephen Tashi said:
Some of those questions are explained in this thread:
https://www.physicsforums.com/showthread.php?t=380389
Thank you for the link. It was very helpful...but I'm still a bit confused about my first and last questions...
Correct. The story of life in probability theory is that there is no deterministic connection between probability and actuality. The important theorems that mention random variables and actual oucomes only speak of the probability of certan actualities (which has a circular ring to to it). The best you can do is find an actuality that has a probability of 1 as some sort of limit is approached.
For your first question - you are right. The maximum is a good guess, but it could easily be wrong.
For you third question, define Yn.
Y_n is the maximum of X_1, ... , X_n. Do we need to look at what E(Y_n) approaches in order to see what Y_n approaches to?
Since E(Yn) -> θ and θ is the maximum of the distribution, the probability that lim Yn is < θ must be 0.
The proof is straightforward. Let A be the event that the limit is < θ, then:
E(Yn) = E(Yn|A)P(A) + E(Yn|A')P(A') -> θ only if P(A) = 0.
