Can Perlite Be Used as Vacuum Insulation for Cryogenic Hydrogen Tanks?
  • Thread starter Thread starter Q_Goest
    Hydrogen
Cryogenic liquid hydrogen tanks utilize an inner and outer vessel design, often incorporating perlite and a vacuum to minimize heat transfer and prevent hydrogen from boiling. Perlite, a volcanic rock, contains a small percentage of water that is released when heated, causing the material to expand and become lightweight. The processing of perlite involves mining, crushing, and heating in a furnace, which results in a significant reduction in density. A key discussion point is whether perlite could adsorb hydrogen gas. It is noted that while hydrogen can be absorbed by metals, perlite's iron oxides do not absorb hydrogen unless they are reduced to elemental iron, a process requiring high temperatures in the presence of hydrogen. This suggests that perlite, in its typical state, is unlikely to adsorb hydrogen gas.
Q_Goest
Cryogenic liquid hydrogen tanks are common in industry. These tanks have an inner vessel and an outer vessel. Between the two, the space is sometimes filled with perlite and a vacuum pulled to reduce heat transfer to a minimum to prevent boiling of the liquid hydrogen.
This is the same volcanic rock used in other applications but it is dried in an oven as described here:
Perlite contains from two to five percent of dissolved or chemically combined water. King, Todd, and Kelly (1) report that water above 1.2 percent is very loosely held. M. T. Hunting (2) reported that only that water below 0.75 percent was firmly held.
Processing perlite (3, 4, 5) is a fairly simple operation. Mining is usually an open pit operation. On leaving the mine the ore is crushed, screened, and stored according to size. The ore is then passed into a preheating furnace at 800 to 1000 degrees Fahrenheit, then into a "popping" furnace at a temperature as high as 1800 degrees Fahrenheit. The product from the furnace is then separated and sized in a cyclone separator.
The operation of the "popping" furnace is interesting. As stated above the perlite has a certain amount of loosely bound water. On heating, the water vaporizes and causes the ore to burst, yielding a product of very low density. It is common for an ore with a density of from 68 to 74 pounds per cubic foot to yield a product with a density of from 5 to 7 pounds per cubic foot.
Reference: http://archives.njit.edu/vol01/etd/1950s/1957/njit-etd1957-003/njit-etd1957-003.pdf
Table 1 in this reference is on page 5 and shows typical chemical composition.
Is it possible that this material in the state described (used as vacuum insulation) could adsorb hydrogen gas? Even a small amount of hydrogen?
Chemistry news on Phys.org
For the record, I asked a friend of mine and got this response:
I don't believe so. Hydrogen is absorbed by many metals in their elemental state but not to my knowledge by metal compounds such as those contained in Perlite.
Perlite contains iron oxides which will not absorb hydrogen unless first reduced to elemental iron. The only way this could occur would be if the iron oxides were reduced by hydrogen first, but this would require heating (eg above 500 deg. centigrade in the presence of hydrogen)
Feel free to comment.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
