What is the Dot Product of Two 2x2 Matrices?
The discussion clarifies the difference between the matrix product and the dot product of two 2x2 matrices. The dot product, also known as the inner product, results in a scalar value rather than a matrix. Specifically, for two 2x2 matrices, the dot product is calculated using the Frobenius inner product formula, which sums the products of corresponding elements. This means that the dot product of the matrices results in a single value, not another matrix. Understanding this distinction is crucial for applying concepts in image processing and linear algebra effectively.
Owen-
This seems like a very basic question that I should know the answer to, but in my image processing class, my teacher explained that a basis set of images(matrices) are orthonormal.
He said that the DOT product between two basis images (in this case two 2x2 matrices) is 0. so, for example
\begin{equation}
\begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
\cdot
\begin{bmatrix}
e & f\\
g & h
\end{bmatrix}
=0
\end{equation}
I don't understand how this can be. I always thought it gave another matrix, and not a direct value:
\begin{equation}
\begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
\cdot
\begin{bmatrix}
e & f\\
g & h
\end{bmatrix}
\begin{bmatrix}
ae+bg & af+bh\\
ce+dg & cf+dh
\end{bmatrix}
\end{equation}
Can someone help me out? It would be unbelieveably helpful,
Thanks!
Owen.
Mathematics news on Phys.org
The only possibility I can think of is to take a 2x2 matrix and write it out in the form ##a e_{11} + b e_{12} + c e_{21} + d e_{22}##, ie as a four dimensional vector space. Then the e's form an orthonormal basis.
\begin{equation}
\begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
\cdot
\begin{bmatrix}
e & f\\
g & h
\end{bmatrix}
\begin{bmatrix}
ae+bg & af+bh\\
ce+dg & cf+dh
\end{bmatrix}
\end{equation}
Thanks!
Owen.
That's the matrix product, not the dot product. A dot product (inner product) is a scalar. Always. For matrices, the typical definition of the dot product is the Frobenius inner product. Simply compute as if the matrix was a vector. For real matrices,
\begin{equation}
A\cdot B \equiv \sum_i \sum_j A_{ij} B_{ij}
\end{equation}
For your pair of 2x2 matrices,
\begin{equation}
\begin{bmatrix}
a & b\\
c & d
\end{bmatrix}
\cdot
\begin{bmatrix}
e & f\\
g & h
\end{bmatrix}
= ae + bf + cg + dh\end{equation}
Perfect thanks a lot!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
