Potential energy and a skateboard, only have until 11:30
The discussion focuses on calculating the change in gravitational potential energy (PE) and the vertical height change of a skateboarder after performing work against friction and through self-propulsion. The skateboarder, weighing 54.5 kg, starts with an initial speed of 1.95 m/s and ends at 6.10 m/s after doing +80.0 J of work while experiencing -265 J of frictional work. The change in potential energy is calculated to be -1095.35 J, indicating a decrease in height. Consequently, the vertical height change is determined to be approximately -2.051 m, suggesting the skateboarder descends. The calculations utilize the conservation of energy principle, incorporating both kinetic and potential energy changes.
kpangrace
Potential energy and a skateboard, only have until 11:30!
A 54.5 kg. skateboarder starts out with a speed of 1.95 m/s. He does +80.0 J of work on himself by pushing with his feet against the ground. In addition, friction does -265 J of work on him. In both cases, the forces doing the work are nonconservative. The final speed of the skateboarder is 6.10 m/s
Calculate the change (PE = PEf - PE0) in the gravitational potential energy
(b) How much has the vertical height of the skater changed?
ok so potential energy is PE=MGH buti don't see a vertical height here!
Please help!
right...
You can define the height to be zero anwhere you like. I would suggest letting the height that he starts at be zero.
Set up your Conservation of Energy equations (ME_i = ME_f, where ME = KE +PE) using variables for any unknowns.
(a) Calculate the change (PE = PEf - PE0) in the gravitational potential energy
{Initial Total Energy} = (1/2)*m*v0^2 + PE0 = (1/2)*(54.5)*(1.95)^2 + PE0 =
= 103.62 + PE0
{Final Total Energy} = (1/2)*m*vf^2 + PEf = (1/2)*(54.5)*(6.10)^2 + PEf =
= 1013.97 + PEf
{Delta Total Energy} = {1013.97 + PEf} - {103.62 + PE0} =
= 910.35 + {Delta PE} =
= {Work Performed On Subject} = (80) + (-265) = (-185)
{Delta PE} = (-185) - (910.35)
A) {Delta PE} = (-1095.35 J)
m*g*{Delta H} = (-1095.35)
{Delta H} = (-1095.35)/{(54.5)*(9.8)}
B) {Delta H} = (-2.051 m)
here's what i did. plug all the numbers into Wnc= (1/2mvf^2-1/2mv0^2)+(mghf-mgh0) and you get Wnc= a number + a number *(h0-hf)
then you go and find Wnc first since it already told you in the question= +80-265 and you get -185. so
-185=a number + a number *(h0-hf) and you can now find out what (h0-hf) equals to. which is close to 2. this is the answer to b (i got 2.15 because our variables are different on webassign)
answer to a. since you know what h0-hf is.
change in PE= mghf-mgh0
plug h0=hf+(your answer to B)
and you get
mghf-mghf-mg*(your answer to B)
mghf cancels out. -mg*(your answer to B) is the answer for A (negative number)
hope that helps...LOL
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
