The Bob
- 1,126
- 0
Coursework time has hit me at college and no matter how much I hit the books the answer is not hitting me.
It might be simple but I can't see it. Of course, the question is needed.
I had to titrate sulphuirc acid with sodium hydroxide. Not hard to write coursework on and I am sure that if I did it without what I am trying to find out (below) then it would be fine but I am not happy just to accept that there should be equal amounts of sulphuric acid and sodium hydroxide to create a neutral solution.
I read in these forums that the molar pH of sulphuirc acid is less than that of the pOH of the sodium hydroxide. For my hypothesis I want to be able to say why I think that there needs to be more sodium hydroixde to create a neutral pH overall.
For what I need help with is the maths, really. I have been studying for the last 4 hours trying to make sense of the dissonance(?) of acids and bases and how this affects the pH or the moles (not even sure which). I installed a system that was posted up here from the 'few questions' thread (called BATE) and it says that for an equal amount of 0.01 mol dm^{-3} concentrations of each susbstance I should get an overall pH of 6.17. I am trying to find out how to get to this number and how I can explain it along the way.
Even if this wasn't coursework I would have ask the same question (actually, to be honest I don't need it in my coursework it is more for interest but I really want to understand it).
Cheers
The Bob (2004 ©)
P.S. After re-reading it I hope it makes sense. What I want to know is how to work out that the pH after mixing, say, 10cm³ of sodium hydroixde to 10cm³ of sulphuric acid (both concentrated to 0.01M) is going to be 6.17, and therefore how much sodium hydroxide is actually needed. Also I will need to explain why so if you know any websites that will do that, to save you writing it, then I would be grateful.
Cheers
The Bob (2004 ©)
