Calculating Max Speed of a Particle on String
  • Thread starter Thread starter vroman
    Harmonic Wave
The maximum speed of a particle on a string in a simple harmonic transverse wave is calculated using the formula 4A/T, where A is the amplitude and T is the period. This calculation is based on the relationship between velocity, frequency, and wavelength, with frequency being 1/T and wavelength equal to 2A. The maximum particle speed is derived from the equation v(x,t) = (ωA)cos(ωt - kx + φ), reaching its peak when cos(ωt - kx + φ) equals 1. The formula reflects that the particle completes two full cycles in one period, thus doubling the speed to 4A/T. This method can be applied to determine the maximum speed for any particle on a string given its amplitude and period.
vroman
For a simple harmonic transverse wave that is propagating along a string toward the right, how is maximum speed of a particle on the string calculated?
Is it
4A/T
If A=amplitude and T=Period?
Is it
4A/T
displacement = s(x,t) = A*sin(ωt - kx + φ)
particle speed = v(x,t) = ∂s(x,t)/∂t = (ωA)*cos(ωt - kx + φ)
max particle speed (when cos=1) = ωA = 2πf*A = 2πA/T
Yes, the maximum speed of a particle on a string can be calculated using the formula 4A/T, where A is the amplitude of the wave and T is the period of the wave. This formula is derived from the relationship between velocity, frequency, and wavelength in a wave, which is v = fλ. In a simple harmonic transverse wave, the frequency (f) is equal to 1/T, and the wavelength (λ) is equal to 2A. Therefore, the maximum velocity can be calculated as v = (1/T)(2A) = 2A/T. However, since the particle on a string undergoes two complete cycles (one full oscillation) in one period, the maximum speed is doubled to 4A/T. This formula can be used to calculate the maximum speed of any particle on a string for a given amplitude and period.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
