Calculating Compression Time for Mass-Spring Impact: A Comparison of Methods
  • Thread starter Thread starter VinceA
    Impact
The discussion focuses on calculating the compression time for a mass-spring system involving a weight dropped onto a spring. The user has validated equations for deflection and force using Shigley's reference but finds a significant discrepancy in the calculated time to maximum deflection compared to simulation tools. The calculated time is 0.00015 seconds, which is 1/100th of the time reported by simulations, raising questions about potential errors in the approach. The user suspects issues related to the treatment of the collision or unit conversions but has ruled out unit discrepancies. The conversation highlights the complexities of accurately modeling dynamic systems in engineering simulations.
VinceA
This is a simple(?) problem but my ability to perform basic calculus disappeared long ago. I am working thru the equations for a spring response to a dropped weight. My primary reference is Shigley (for just about everything!) and I've validated the eqn's for deflection and max force. However, I am trying to work out the duration of the event for purposes of estimating simulation time in explicit FEA. Solving for time to max deflection from eqns in Shigley yields exactly 1/200th of the time reported by 2 mechanism simulation tools...who nail the deflection and force as noted above.
Has anyone solved this "compression time" and, if so, can you share the eqn?
Not that you're giving a whole lot of info, but based on what you have listed, I would guess that:
1. You've got one side dealing with the whole colision, and the other dealing with half of it (introducing a factor of 2)
and
2. There's some sort of unit issue providing a factor of 100.
Note that this is a relatively wild guess.
I've beat up the units issue so I don't think that's the problem. The system is pretty simple and I've been staring at it for a couple of hours so it didn't occur to me to give more detail... Essentially, I'm looking at a spring to ground with K=238.1 #/in. A weight (W) of 7.43# is being dropped a height (h) of 12 inches onto the spring.
Compression (D) = (W/k)+(W/k)*SQRT[1+((2*h*k)/W)] = 0.897 in.
Force (F) = K*D = 213.6 lbf
Both these calcs agree with the simulation results.
In Shigley "Mechanical Engineering Design", D is determined by assuming a Cosine term in a longer eqn is unity...
Cos[(kg/W)t - Phi] = 1
thus...
(kg/W)t-Phi = 0 or (kg/W)t = Phi or t = (Phi*W)/KG
Phi = Pi/2 + SQRT[atan(W/(2kh))] = 1.84
thus... t = 0.00015 sec
which is 1/100th (not 1/200th...sorry) the duration reported by simulation.
Can anyone see where I messed up? I, of course, waited until the last minute before deciding I wanted to add this to a slide in a webcast tomorrow.
Thanks!
...is your calculator set to degrees?
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
