Extract caffine from coffee beans / tea leaves
  • Thread starter Thread starter phr34k
    Coffee
The discussion focuses on methods for extracting caffeine from coffee or tea. One suggested method involves using dichloromethane (DCM) for extraction, which includes adding sodium carbonate to coffee, mixing with DCM, and separating the layers to isolate caffeine. However, this method has health risks and is no longer used industrially for decaffeination. An alternative method mentioned is using superheated steam, commonly associated with espresso preparation. The conversation highlights the importance of safety and the effectiveness of different extraction techniques.
phr34k
i was wonderin in there was an eaisy way to extract caffeine from coffee or tea. i read aroun and there was 3 methods of doing this one of which involved water, but I am not too sure how i can get the caffine by it self?
can anyone give me a step-by-step?
thanks
phr
Chemistry news on Phys.org
I imagine all you would have to do is an extraction followed up by an evaporation of an organic solvent. I would probably try taking some coffee and add some NaCO3 followed by adding some DCM. after swirling the solution I would funnel off the bottom layer, which should be the DCM layer and which should contain the caffeine. I would then take the DCM layer and dry it over some magnesium sulfate to get all the rest of the water out. Then after you evaporate off the DCM you should have isolated some caffeine.
Yes, dichloromethane was used industrially to extract caffine from coffee to make it decafinated. This method is no longer used because of health risks.
Drink it...
The water one you're talking about is passing superheated steam through finely ground coffee. The common name for this is "espresso".
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
