Diverging Series: Proving Logarithmic Divergence with Real x
  • Thread starter Thread starter happyg1
    Divergent Series
happyg1
Hello, I'm working on this problem:
Prove that for any real x, the series SUM n=2 to infinity of 1/(log n)^x diverges.
So far, I have applied the test that says that if SUM 2^n*a_2n converges then the series converges. I got:
1/log2*SUM 2^n/n^x I know that 1/n^x converges if x>1, but 2^n will explode, so I'd have convergent (sometimes) times divergent = divergent. Can I do that?
Thanks,
CC
No, that is not a propery of series. A counter exemple is
\sum \frac{1}{n}\frac{1}{n^2}
In this case, we have divergent times convergeant = convergeant.
What you can do to prove the desired result however, is simply show that for all x in R, the limit as n-->infty of the argument of the serie is not 0. Hence it does not converges, hence it diverges. (You'll have to do the 3 separate cases x<0, x=0 and x>0 [the later being the most difficult]).
I tried it using the ratio test. I got
\2(\frac{n}{n+1})^x[\tex]<br /> and the limit of that is 2&gt;1 so it diverges.<br /> can I do it that way?<br /> CC
let me try again...I'm still learning latex...
\mbox{2}(\frac{n}{n+1})^x
there. And the limit of THAT is 2.
Is this correct?
Is this correct?
Yes.
\lim_{n \rightarrow \infty} 2 \left( \frac{n}{n+1}\right)^x=2[/itex]<br /> <br /> But<br /> \frac{(\log n)^x}{(\log n+1)^x} \neq 2 \left( \frac{n}{n+1}\right)^x
You should do it my way. It's much more instructive then mechanically using a test anyway.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
