A math or a simple fluid problem?
  • Thread starter Thread starter hanson
    Fluid
The discussion revolves around solving a differential equation for the height of a tank over time, considering a constant inflow and a fluctuating component. The inflow is defined as a + bsin(wt), while the outflow is proportional to the square root of the height, represented as c*sqrt(H). There is uncertainty regarding the assumption of the outflow's relationship to height, with suggestions to revise this aspect. Additionally, a participant recommends expressing the radius in terms of height to simplify the equation. The overall consensus is that the problem is more mathematical than fluid dynamics.
hanson
Hi all!
I am solving for the height of a tank as a function of time.
The tank has a constant inflow of a and is subjected to small fluctuation of bsin(wt).
So the inflow is simply a+bsin(wt).
The outflow should be proportional to the square root of the height, H.
So outflow = c*sqrt(H)
Therefore the below differential equation is obtained with k=the area of the tank:
\frac{a+bsinwt-c\sqrt{H}}{k}=\frac{dH}{dt}
but the problem is that I don't know how to solve this ODE...
Can anyone solve the problem?
Have you been given this equation or have you set it up by yourself?
I set it up myself. And I have show my deduction:
Therefore the above differential appears.
Am i correct?
Am i correct?
I am not sure about your assumption of the outflow. I would revise that.
this problem really has nothing to do with fluids..its just a math problem..
inflow is a+bsin(wt) correct.
outflow you said is proportional to square root of the height, h..
is then right too.. c*sqrt(h)...
now if you divide volume by cross sectional area you get height.. I am thinking you need to find the radius in terms of height also by rearranged the volume equation... that way your equation will be composed only of H terms.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
12K
