Energy-momentum density of point particle
The discussion centers on the formulation of the energy-momentum tensor for a point particle in the context of special relativity and its potential inconsistencies in general relativity. Participants explore mathematical representations and transformations involving delta functions and four-vectors.
  • One participant presents a formulation for the energy-momentum tensor of a point particle, suggesting it involves a delta function and a specific mathematical structure derived from the tensor for dust.
  • Another participant expresses uncertainty about the mathematical consistency of the stress-energy tensor for a point particle, referencing previous discussions and inviting input from another member.
  • A third participant indicates agreement with the initial formulation, noting similarities with their own approach.
  • Concerns are raised about the implications of point masses and metrics in general relativity, suggesting that issues may be less significant in special relativity.
  • One participant discusses the nature of the delta function in relation to four-vectors, comparing it to the four-current of a point charge and noting that certain formulations may not yield valid four-vectors.
Participants do not reach a consensus on the mathematical formulation of the energy-momentum tensor for a point particle, with some expressing agreement on specific aspects while others raise concerns about consistency and applicability in different contexts.
There are unresolved questions regarding the mathematical consistency of the stress-energy tensor for point particles, particularly in the context of general relativity versus special relativity. The discussion also highlights the dependence on the definitions and transformations used in the formulation.
jostpuur
I'm using a following notation. [itex](v^1,v^2,v^3)[/itex] is the usual velocity vector, and
[tex] (u^0,u^1,u^2,u^3) = \frac{1}{\sqrt{1-|v|^2/c^2}}(c,v^1,v^2,v^3)[/tex]
is the four velocity.
So a energy-momentum tensor of dust is
[tex] T^{\mu\nu} = \rho_0 u^{\mu} u^{\nu} = \frac{\rho_0}{1-|v|^2/c^2}\left[\begin{array}{cccc}<br /> c^2 & cv^1 & cv^2 & cv^3 \\<br /> cv^1 & v^1 v^1 & v^1 v^2 & v^1 v^3 \\<br /> cv^2 & v^2 v^1 & v^2 v^2 & v^2 v^3 \\<br /> cv^3 & v^3 v^1 & v^2 v^3 & v^3 v^3 \\<br /> \end{array}\right][/tex]
My first though was, that a energy-momentum tensor of a point particle would be this multiplied with a delta function, but after some struggling with the transformations of the delta function, I concluded that the result is, nontrivially
[tex] T^{\mu\nu} = m_0 \delta^3(x-x(t)) \sqrt{1-|v|^2/c^2} u^{\mu} u^{\nu}<br /> = \frac{m_0\delta^3(x-x(t))}{\sqrt{1-|v|^2/c^2}}\left[\begin{array}{cccc}<br /> c^2 & cv^1 & cv^2 & cv^3 \\<br /> cv^1 & v^1 v^1 & v^1 v^2 & v^1 v^3 \\<br /> cv^2 & v^2 v^1 & v^2 v^2 & v^2 v^3 \\<br /> cv^3 & v^3 v^1 & v^2 v^3 & v^3 v^3 \\<br /> \end{array}\right][/tex]
Is this correct?
I'm not sure whether or not there is a totally mathematically consistent formulation of the stress-energy tensor of a point particle or not. See for instance Stingray's comments (and more importantly his references) in the old thread
https://www.physicsforums.com/showthread.php?t=111148
If stingray is around, maybe he could comment in more detail.
This looks the same as what I got.
In that post, I initially used inertial motion along the x-axix, Y means [itex]\gamma[/itex] and (x) means [itex]\otimes[/itex].
It seems there are some problems with point masses and metrics in general relativity, if I understood stingray's comments correctly. In special relativity that can probably be ignored.
My derivation went through the fact that
[tex] \delta^3(x-x(t))(c,v)^{\mu}[/tex]
is a four vector, like a four current of a point charge, and for example
[tex] \delta^3(x-x(t)) u^{\mu}[/tex]
is not. Good to see that George Jones got the same factors in a different way.
  • · Replies 38 ·
  • · Replies 17 ·
  • · Replies 55 ·
  • · Replies 50 ·
  • · Replies 26 ·
  • · Replies 31 ·
