Implementing Hall Effect Sensor
  • Thread starter Thread starter sbagliato
    Hall effect Sensor
To measure the magnetic field produced by a solenoid using a Hall Effect Sensor, it is essential to ensure proper sensor setup and orientation. Users are advised to refer to datasheets for similar devices to understand expected output voltages and optimal sensor positioning. The sensor typically requires a 5-volt power supply and outputs 2.5 volts in the absence of a magnetic field. For effective measurements, a strong DC current should be applied to the solenoid, and testing the sensor near a permanent magnet can help verify its functionality. Proper amplification may be necessary due to the low output voltage of Hall Effect Sensors.
sbagliato
Hi, I am working with a solenoid and I am trying to measure the magnetic field that it can produce using a Hall Effect Sensor but I cannot seem to get any results from the sensor. Does anyone know how this is suppose to be done? Thanks.
Welcome to the PF. What sensor are you using? Can you post a schematic of how you are hooking it up?
it is a linear hall effect sensor but I was not able to find out the specific model (the sensor was given to me). I have attached a PDF with the basics of my set up. Is it conceptually correct?
I would look for similar devices on the Internet, and download a datasheet for a similar device. That should give you an idea of what kinds of output voltages to expect for different fields. And also let you know what direction to turn the sensor to have the B-field have the maximum effect on the output voltage.
Look at Allegromicro for Hall Effect sensors. Digikey has a few models. See
www.digikey.com
http://search.digikey.com/scripts/DkSearch/dksus.dll
http://www.allegromicro.com/en/Products/Categories/Sensors/index.asp
These will not work easily unless your solenoid is DC.
[Edit] This is one Allegro unit available at Digikey:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=620-1024-ND
The magnetic field is perpendicular to flat face. They have 16,545 in stock; $1.74 each. Linear field sensor, 5.25 Gauss per millivolt.
You want the 3-SIP or SIP-3 case. What is the maxumum thickness you can use?
Hall effect sensors have very low output voltages and even the ones that have internal amplifiers are not very sensitive.
Try holding it near a strong permanent magnet at one of the poles and verify that the voltage output changes when you rotate the sensor.
You would need a large DC current in a big flat solenoid to get a good deflection without further amplification.
Typically, they need a 5 volt power supply and the output is 2.5 volts when they are not in a magnetic field.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
