Calculating avg distance from nucleus
  • Thread starter Thread starter jaejoon89
    Nucleus
jaejoon89
Calculate the avg. distance from the Hydrogen nucleus for an electron in 2p.
<r> = int[r^3 |R|^2]dr from 0->infinity
For Hydrogen 2p, R = (1/a)^3/2 (1/(2*sqrt(sigma))*sigma*exp(-sigma/2)
where sigma = r/a
I get 1/4a^4 (24 a^5) = 6a but the answer's supposed to be 5a. (5a for 2p is supposed to be less than 6a, which is the avg distance for 2s.) What am I doing wrong?
That's only true when the wavefunction is spherically symmetric. In general,
\langle r\rangle=\int_{\text{all space}}r|\psi(\textbf{r})|^2d^3\textbf{r}=\int_0^{\infty}\int_0^{\pi}\int_0^{2\pi}|\psi(\textbf{r})|^2r^3\sin\theta dr d\theta d\phi
where sigma = r/a
That doesn't look quite right. Where did you get this from?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
