Need help with 3-moment equation (multi-span beams)
  • Thread starter Thread starter XaeroR35
    Beams
The discussion centers on solving a three-span continuous beam problem with a uniform distributed load in the middle span using the Equation of Three Moments. The user is struggling to determine the values of centroids and areas of moment curves for each span, realizing they have six unknowns but only two equations. They express confusion about whether additional equations are needed to solve the statically indeterminate case. Suggestions include defining terms clearly and considering alternative methods for solving the problem. The user expresses a desire to understand the manual solution rather than relying on a spreadsheet.
XaeroR35
It has been a few years since I have done beam analysis, and I really don’t remember how to solve this type of problem so I have been reading up on it. I have found similar situations but nothing that matches the problem I am having.
I have a continuous beam of 3 spans with a uniform distributed load centered in the middle span (not full width).
I believe I need to use the Equation of Three Moments to solve this with Matrices, but I am stuck.
Since my material and cross sections are the same for the beam, I believe my 3-moment equations reduce to:
(M1*La) + (2*M2*(La+Lb)) + (M3*Lb) = - (6*xa*Aa)/(La) - (6*xb*Ab)/(Lb)
(M2*Lb) + (2*M3*(Lb+Lc)) + (M4*Lc) = - (6*xb*Ab)/(Lb) - (6*xc*Ac)/(Lc)
How do I get xa, xb, xc, and Aa, Ab, Ac? I understand these to be the centroids and areas of the moment curves for each span, but I am really struggling to come up with their values.
It's been too long for me too. But it appears you have six unknowns and only two equations. Am I missing something? Or is that what you need, 4 more equations?
Sum of loading = sum of reactions
Deflection at supports = 0
That's 5 more?
S
This is a statically indeterminate case, which requires special methods to solve, one of which is the three-moment equation.
I just can't find an example with this loading condition. I found point load, and uniformly loaded across the entire span, just not uniform load at a small section.
R35,
You need to define your terms, and you need to include w, the load, and the length of the load, it looks like it's about the center quarter of the middle span. If it's symmetric you can probably simplify it although it will still be statically indeterminate.
There are other ways to solve your beam problem, unless the 3 moment equation is your interest maybe try another method. S
I know all the terms, I just don't know how to solve this problem. I sketched it quick to give an example of what I am trying to do.
I found a spreadsheet that solves this, but I would like to know how to do it by hand. I have not done beam analysis since school (8+ years ago)
It's helpful to others if you define the terms. S
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
