Finding the Foci of a Quadratic: Working with y^2=1-2x^2
  • Thread starter Thread starter wat2000
    Quadratic
To find the foci of the quadratic equation y^2 = 1 - 2x^2, it needs to be rewritten in the standard ellipse form x^2/a^2 + y^2/b^2 = 1. The equation can be rearranged to 2x^2 + y^2 = 1, which must match the standard form. By comparing coefficients, it is determined that a^2 = 1/2 and b^2 = 1, leading to the values of a and b necessary for the ellipse. The positions of the foci can then be derived from these values, as detailed in standard textbooks on the subject. Understanding the relationship between a and b is crucial for locating the foci accurately.
wat2000
y^2= 1- 2x^2
im supposed to put it in x^2/a^2 + y^2/b^2 = 1 to find the foci and so forth.
when i try to set it up i get 2x^2 + y^2 = 1. I am not sure where to go from here. if i multiply or divide to set the problem up properly the 1 will change and my equation will be messed up. can someone show me what my next step is?
Try match the equation for your particular ellipse, 2x2 + y2 = 1, with the general equation for an ellipse which you have also written up. What value must a and b have in order to match your equation?
should I put everything over 1? so that the 1 stays the same?
I think you misunderstand. If you compare the equation 2x2 + y2 = 1 with x2/a2 + y2/b2 = 1, then what value must a and b have for the two equations to have the same set of solutions, that is, for them to express the same ellipse?
Hint: 2x2 must be equal to x2/a2 for all x, and likewise y2 must equal y2/b2 for all y. Solving these two equations will to get you a and b, and from these you should be able to derive the position of the loci (you may want to look in your textbook on how this position is related to the value of a and b).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
