How to Sketch the Curve y^2 = x^3?
  • Thread starter Thread starter aurao2003
The equation y^2 = x^3 leads to the function y = ±x^(3/2), indicating that the graph has two branches, one above and one below the x-axis. The shape resembles that of a parabola but is steeper for x > 1 and lower for 0 < x < 1. The derivative dy/dx = ±1.5x^(1/2) confirms the presence of two branches in the slope as well. To sketch the curve accurately, both branches should be included, reflecting the symmetry about the x-axis. Understanding these characteristics is crucial for proper graphing of the equation.
aurao2003
Hi everyone, I am not sure how to sketch this:
y^2 = X^3
I have a feeling it will form a parabola.
If I find the square root of both sides I get:
y = X^3/2
Differentiating gives me
dy/dx = 1.5X^1/2. Kind of stuck from here. Please help.
Think about the shape of the graph for y=x2, then y=x3, y=x4 etc. only for values x>0. The shape is roughly the same, no? The only difference is that for x>1 the graph is steeper and for 0<x<1 the graph is lower for larger powers.
So y=x3/2 will be roughly the same as y=x2 for x>0
But remember that when you take the square root of both sides, you need to remember that \pm so your final result of y^2=x^3 or y=\pm x^{3/2} is the graph of y=x3/2 for values of x>0 and then exactly the same thing but reflected in the x-axis for y=-x3/2.
y^2 = X^3
y = X^3/2
Actually, it's
y = \pm x^{3/2}
There are two branches.
The derivative also has two branches.
dy/dx = \pm 1.5x^{1/2}
aurao2003 said:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
