Example question on pressure of liquids
When designing a dam, both the horizontal extent of the water and the vertical depth must be considered, as they impact the total force exerted on the dam. The length and thickness of the dam wall are crucial since the force is proportional to the area, which is influenced by both dimensions. Pressure is determined by depth, meaning that regardless of the water's volume, the pressure remains consistent at the same depth. Additionally, the design of long dams often incorporates curved shapes to better withstand these forces. Understanding these principles is essential for effective dam engineering.
jayadds
This question seemed a bit abstract to me, maybe some of you could come up with an answer with explanation?
When designing a dam should one consider the horizontal extent of the water behind the dam or the vertical depth of the water? Justify your answer.
Thanks.
Hi Jayadds,
Do you mean the length of the dam wall?
Hassan2 said:
Hi Jayadds,
Yes, I mean the length of the dam wall as well as the thickness.
I'm not an expert in this field but according to my limited knowledge, the length of the wall does matter because the total force on the wall is proportional to area and the area is proportional to the wall length as well as to the water depth ( thickness). But a more detailed explanation is about stress and strain of the wall under the forces. Long dams are build oval-shaped or in other curved surfaces to resist the forces.
hi jayadds! :smile:
jayadds said:
When designing a dam should one consider the horizontal extent of the water behind the dam …
i think that means, how far away the water extends from the dam :wink:
Depth determines pressure, not volume. This means that whether you're at the bottom of the ocean or at the bottom of a narrow well, as long as the water depth is the same, the pressure and force on you will also be the same.
tiny-tim said:
hi jayadds! :smile:
This.
And to answer the original question with another, just think about it a bit. What affects the pressure, how deep you are or how much water you have around you?
