Intensive Properties of a system- density
Density is defined as mass divided by volume, leading to confusion about its classification as an intensive property. While mass and volume are extensive properties that depend on the amount of substance, density remains constant when both mass and volume change proportionally. This means that if an object's mass doubles, its volume also doubles, resulting in unchanged density. The key to understanding density as an intensive property lies in recognizing that it does not vary with the size of the sample. A practical way to visualize this is by considering an object and imagining it cut in half; the density remains the same for both halves, reinforcing that density is independent of the amount of material present.
leah3000
How is density an intensive property?
If density= mass/ volume
wouldn't the density increase as the mass increases seeing that they are directly proportional?
I'm seeing this in my Uni lecture slides on thermodynamics; that density is an intensive property which means it is mass independent but I don't understand that. Is it an error? Or am I thinking of this in the wrong way?
Chemistry news on Phys.org
Only if you would be able to keep the volume constant.
Ok so i understand that part, but won't the density still fluctuate more or less once the mass or volume is altered?
I guess I'm confused a bit because both mass and volume are extensive properties...so why is density intensive?
Usually if you take the ratio of two extensive quantities, you will get an intensive quantity. If you double the mass, you also double the volume so the factors of two cancel out when you take the ratio, and density remains the same.
I was taught to imagine the object and then cut it in half and ask yourself if that property has changed. Makes it pretty simple to see how a block of iron, for example, will have the same density as the two blocks you can make by cutting the original in half.
Its not a rigorous mathematical proof, but it helps clear things up when you're unsure.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
