Does the angle of fall affect the change in kinetic energy of a log?
The discussion explores whether the angle of fall affects the change in kinetic energy of a log. Two scenarios are presented: one where the log falls straight down and another where it falls at a 60° angle. Despite the difference in the distance between the center of masses in each case, the kinetic energy remains unchanged. Both scenarios result in zero kinetic energy after the log comes to rest, as they both had the same potential energy just before impact. The conclusion emphasizes that no energy is required to move the log from one stationary position to another.
Manula
There is a uniform log lying on the ground.Now we can lift this up from one end such that the other end is in contact with the ground.Now keep the log vertical.
Case 1: Let the log fall freely such that when it comes to rest it is inline with the initial position of the log.
Case 2: Let the log fall freely such that it makes angle(say 60°) with the initial position when it comes to rest.
My question is, in the two cases the distance between the center of masses of the log in its initial position and final is different, Even though the cases are similar.
What causes this difference?
Hi Manula! :smile:
Manula said:
… in the two cases the distance between the center of masses of the log in its initial position and final is different, Even though the cases are similar.
There's no difference in kinetic energy
they both end up with zero KE (and they both had mgh KE just before they hit the ground) …
we don't need any energy to move something from one stationary position to another! :wink:
tiny-tim, Thank you! :)
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
