Gauge Symmetry in Quantum Mechanics (QM I) Explained
the_kid
Hi all,
I'm taking graduate level QM I and trying to wrap my head around the notion of gauge symmetry. For some reason I've struggled with this concept more than others. I don't really have a specific question; I'm more looking to see if someone has a succinct explanation of the relevant details - or perhaps a good source to read.
Thanks!
-TK
OK, I've done some more reading on my own and now have a specific question. Hopefully this will get this thread moving.
It is my understanding that for a quantum system to be locally gauge invariant, it must be in the presence of an EM field. I understand mathematically why this is true (at least roughly), but I'm wondering if there is a physical explanation for it. Any input?
Actually the gauge symmetry is classical in origin, and most of the quantum systems also admit a classical picture (especially in field theory). So that you can write down a fully classical lagrangian (density if needed) as a sum between the purely gauge field and the "matter field", i.e. the Schrödinger, Dirac fields. Then apply specific methods of quantization (i.e. converting clasical Poisson/Dirac brackets to (anti)commutators) to get a meaningful quantum theory.
Yes, the EM field in vacuum is the most proeminent example of gauge field, but the linearized (Fierz-Pauli) gravity field is also a gauge field. Likewise for a collection of covector fields (so-called Yang-Mills fields).
EM field is not any necessity,however the idea of local gauge invariance came from electromagnetism which is an abelian gauge field i.e. the commutator [Aμ,Av] vanishes which is not the case with non abelian gauge fields.It is used in the work of yang and mills.
I do not think this is a good way to describe what gauge invariance is. It is not the system that is invariant, but the predicted quantities, like probability or average values, are invariant. In non-relativistic theory, the situation is as follows:
-there is Schroedinger's equation for \psi, which can be formulated in the presence of external electromagnetic field; this is accomplished by use of electromagnetic potentials \varphi, \mathbf A;
-|\psi(r)|^2 is interpreted as probability density that certain configuration r occurs; and \frac{1}{m}\mathrm{Re} (\psi^* (\mathbf p - \frac{q}{c}\mathbf A)~ \psi) is intepreted as probability current density in space of these configurations;
- the Schroedinger equation is such that the change of electromagnetic potentials which leaves fields E,B the same (change of gauge) does not change the above kind of quantities.
Thus the gauge invariance is the invariance of probabilities calculated from Born's rule. Or it can be invariance of all other quantities calculated from these, such as average expected position or momentum.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
