What is the meaning of A^(⊥) in a mathematical context?
  • Thread starter Thread starter mikeph
    Mean
In the mathematical context, A^(⊥) refers to the orthogonal complement of a set A, denoted as R⊥, which consists of all elements that are orthogonal to every element in R. The symbol "⊕" represents the direct sum, indicating that any element x can be uniquely expressed as the sum of two components, one from R and one from R⊥. This means x is in the direct sum R ⊕ R⊥ if it can be written as x = a + b, where a ∈ R and b ∈ R⊥. The perpendicular symbol indicates a relationship of orthogonality, commonly used in linear algebra and functional analysis. Thus, if R is the real line, R⊥ would represent a line perpendicular to it, forming a plane with the direct sum.
mikeph
I'm looking at a condition in a maths paper that I don't understand, essentially it is:
x ∈ R ⊕ R
R is a set I think, but I'm not sure what the perpendicular symbol means.
Also am I correct in thinking the circled plus means that x must be in either R or R (but not both)?
Thanks
Mathematics news on Phys.org
The upside down capital T means <perpendicular>, both in elementary geometry and in linear algebra (or functional analysis). A to the power T upside dowm is the subset B of M made up of all y in M, such that whatever x from the subset A of M, <x,y> = 0, where (M,<,>) is a scalar product space.
x ∈ R ⊕ R
It's usually read as "R perp".
If "R" is the real line, then "R perp" is a line perpendicular to it. Their direct sum is the plane containing the two lines.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
