What is the geometric property of these 2 angles being equal?
Lebombo
At time 2:20, the woman says, "Using trigonometry, we know that this angle is the same as this angle."
Which trigonometry or geometry property is she referring to that is needed in order to determine those two angles are equal? Is there a name for it? I don't have a geometry book, but I am interested in learning about it. Any information would be helpful.
Thank you.
The sum of the angles in a triangle is 180. a+23.5+90=180 a=66.5
Then a+θ=90 66.5+θ=90 θ=23.5
ah, thanks
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
