Understanding the Equalizing Nature of Negative Feedback in Op Amps
  • Thread starter Thread starter sidvelu
    Amp Op amp
Negative feedback in operational amplifiers (op amps) ensures that the output adjusts to equalize the positive and negative inputs. If the negative input is lower than the positive, the output increases, raising the negative input voltage closer to the positive input. Conversely, if the negative input is higher, the output decreases, driving the negative input down. This equalization principle applies to both inverting and non-inverting configurations, as the feedback mechanism is central to their operation. Understanding this concept clarifies how op amps maintain stability in various applications.
sidvelu
I understand how to apply op amps, but one thing about op amps had bugged me for some time. I want to know what about an op amp in negative feedback forces both the posotive and negative inputs to be equal. And could your explanation be for both an inverting and non inverting op amp.
Thanks! :)
Welcome back to PF.
If the (-) input were significantly lower than the (+) input, that would drive the output high, since V_{out}=A\cdot(V_+-V_-). And because of the feed back to the (-) input, driving the output high would raise the voltage at (-) input, driving it closer to the voltage at the (+) input.
A similar argument applies to considering if the (-) input were significantly higher then the (+) input.
Not sure what you mean here. Op amps are not "inverting" or "non inverting", those terms refer to the two inputs of any op amp. The explanation only works for feedback to the inverting input, that I refer to as (-) above.
oh okay, that makes more sense now. I should've drawn that conclusion on my own, but i guess i was just being stupid.
Thanks alot!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
