Entropy of a continuous system
Defining the entropy of a continuous system, such as the electromagnetic field, poses challenges due to the infinite dimensionality of phase space. Traditional methods like the log of phase space volume are inadequate, as they lead to infinite energy issues. Instead, entropy density, which is the entropy per unit volume, offers a viable approach, although it is not conserved outside reversible processes. The discussion emphasizes the need to consider each infinitesimal volume element as an open equilibrated system to calculate total entropy by integrating the entropy density across the entire volume. This method accounts for the rate of entropy creation due to irreversible processes, providing a more statistical framework for understanding entropy in continuous systems.
dEdt
How could the entropy of a continuous system, like the electromagnetic field, be defined? Obviously you can't use something like the log of the phase space volume, but I can't think of anything that would work.
Science news on Phys.org
Why do you think so? I think you may be right, since the number of Fourier variables (harmonic oscillators) is infinite, which makes the energy infinite.
What's wrong with phase space volume? You can still write the Hamiltonian for a continuous system - it would just be a field theory now.
Andy Resnick said:
If you can assign a temperature (which you can for blackbody radiation), you can define the entropy:
http://128.113.2.9/dept/phys/courses/PHYS4420/BlackBodyThermo.pdf
Thanks for the paper, but I'm looking for a more statistical approach.
Well, the phase space of a field is infinite dimensional. I wouldn't even know how to define volume, and if I could I'd think the volume of basically any region would be infinite.
Google is your friend:
http://home.comcast.net/~szemengtan/StatisticalMechanics/QuantumStatisticalMechanics.pdf
Section 5.3
Use the entropy density (entropy per unit volume). It will, of course, not be conserved except for reversible situations. In general, there will be a rate of entropy creation per unit volume due to irreversible processes. If s is entropy density, then \frac{\partial s}{\partial t}+\nabla \mathbf{J}_s=\frac{\partial s_c}{\partial t} where s is entropy density, \mathbf{J}_s is the entropy flux, and \partial s_c/\partial t is the rate of creation of entropy density (always non-negative).
For example, for a simple fluid, the fundamental law says dU=T dS-P dV+\mu dN where U is internal energy, T is temperature, S is entropy, P pressure, V volume, \mu chemical potential, and N the number of particles. So it follows that dS=(1/T)dU+(P/T)dV-(\mu/T)dN and in terms of densities: \frac{\partial s}{\partial t}=\frac{1}{T}\frac{\partial u}{\partial t}-\frac{\mu}{T}\frac{\partial n}{\partial t} where u is internal energy density and n is particle density. And so forth.
In statistical mechanics terms, you are considering each infinitesimal volume element to be an open equilibrated system. To find the total entropy, integrate the entropy density over the total volume.
