Quiscent voltage as mention in my hall sensor
  • Thread starter Thread starter proing
    Sensor Voltage
The discussion centers on issues with a hall sensor that is not responding linearly to changes in magnetic field strength, displaying only high or low values instead. The sensor's quiescent voltage is expected to be 2.5V but is currently reading 0.7V, which may indicate improper biasing. Suggestions include testing with a non-rare Earth magnet, as the current magnet may be saturating the sensor. Proper biasing is emphasized as a crucial step to resolve the voltage issue. Addressing these problems is essential for achieving accurate sensor readings.
proing
Hi!
I am using this hall sensor http://docs-europe.electrocomponents.com/webdocs/0d88/0900766b80d88153.pdf
i got 2 problems:
1. When i vary the magnetic field, the hall sensor is acting like digital, i mean, it showing either high value or low value... Its not varying linearly as the distance between the magnet and sensor varies.
2. The quiscent voltage of this sensor is 2.5V (that is, the hall voltage must be 2.5V without the magnetic field), but it showing 0.7V.
I am playing with this voltage only, when i bring the north pole of the magnet near to the sensor, the reading is 0.1V and moves away it showing 0.7V (like digital)
Please help me out..
Thanq
1. You may be saturating the sensor. The range of B fields over which it is linear is small (or smaller than the magnet you are using). A rare Earth magnet can be as high as 10,000 gauss. The transfer ratio is 2.5 mV- 5 mV /G. Try using an Alnico or similar non-rare Earth magnet to test it. However...
2. This may be part of the problem - solve it first because you may not be biasing the device properly in the first place.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
