Power & Magnetism: Calculating Resistance & Loss
  • Thread starter Thread starter abdo799
    Magnetism Power
A solenoid generates DC voltage when a magnetic field passes through it, and power can be calculated using Ohm's law and the formula P=VI. While there is power loss due to resistance (Joule effect), the opposing magnetic field from the induced current (Lenz's law) does not contribute to power loss; rather, it is essential for energy conservation. When a magnet moves through a stationary coil, it produces AC output, visible as a sine wave on an oscilloscope. The induced back EMF increases the difficulty of moving the magnet, requiring greater force and resulting in higher induced current. Overall, the power needed to move the magnet equals the power generated in the coil, with resistance causing some energy to be lost as heat.
abdo799
If we have a solenoid and a magnetic passes through it , it will produce a dc voltage in the wire . If we want to calculate the power , we find out the current using ohms law then we use P=VI . I know there is power loss due to the resistance ( joule effect) . But what about the opposing magnetic field due to current in the wires (lenz's law) , does it contribute in the power loss ?
if you have a stationary coil and a magnet " MOVING" through that coil you don't get dc but AC.
If you would look at an oscilloscope you would see a one half of a sine wave.
If you would continue to push the magnet back and forth at a fixed speed you would get a sine wave output.
The back EMF due to the induced current it pushes against the magnet so to speak so it will get harder for you to push that magnet through.
The faster you will try to push the magnet the harder it will become to do that.You will need to supply a greater force to the magnet which will equal in greater current induced.
Likes 1 person
There really isn't a loss of power. The amount of power required to push the magnet through will be equal to the total amount of power generated in the coil. However, due to the resistance of the wire, some of the power will be used to heat the wire instead of performing useful work. The opposing magnetic field doesn't cause a loss of power. Instead it is a requirement in order to conserve energy. Without the opposing magnetic field it wouldn't require any work to move the magnet through the coil and you would be creating energy from nothing.
Likes 1 person
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
