Gravitational or inertial mass gain in cern ?
Hadrons in the LHC gain mass as they approach relativistic speeds, resulting from the conversion of energy into mass according to E=mc^2. This increase in mass is primarily an increase in inertial mass, rather than active gravitational mass, which is too small to measure accurately. While their energy contributes to active gravitational mass, the gravitational effects of moving masses are complex and not simply a matter of increased mass. The hadrons do not reach the speed of light but come very close, only a few kilometers per hour away. The discussion clarifies that the mass gain is a result of energy conversion during high-energy collisions, not a transformation of existing mass.
Alex_P
Hi,
I have been reading about CERN for a while and found amazing - amongst many other things - the fact that hadrons in the LHC turn some of their energy to mass after having reached the maximum possible speed. However this statement was not clear enough. I was wondering whether the mass they gained was their Inertial or their Active Gravitational. Do they really get heavier or is it just an increase of their inertia?
Thank you in advance,
Alex
It's real mass. The result of E=mc^2 or m=Ec^-2.
As they approach the speed of light, the affect is enormous.
They increase their inertia, that is sure and easy to see. The active gravitational mass is far too small to measure it. According to GR, their energy is a contribution to active gravitational mass (in our lab frame), but the gravitational effect of moving masses is more complicated than a simple increase in mass.
They don't turn something into something else. In collisions, a fraction of their energy is used to create new particles.
That does not happen, but they are very close to the speed of light (some km/h away from it).
Thank you for your replies! You 've both been most informative!
I meant the hadron's maximum possible speed which is of course less than the speed of light.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
