Induction Motor Speed: Electrical vs Mechanical
Electrical speed in an induction motor refers to the speed of the rotating magnetic field, determined by the AC frequency and the number of pole pairs. Mechanical speed, on the other hand, is the actual speed of the rotor, which is influenced by slip, the difference between electrical speed and mechanical speed. The relationship between the two is that electrical speed equals the number of pole pairs multiplied by mechanical speed. Understanding this distinction is crucial for analyzing motor performance and efficiency. The discussion highlights the importance of these concepts in the context of induction motors.
theanwin
Hello Everybody,
Can anyone explain, what is thee difference between 'electrical spped' and 'mechanical speed' of rotor in an induction motor? what do they signify? Many literatures say that electrical speed is no of pole pairs times mechanical speed, if somebody can explain...
Thanks
Hey, Thanks for your reply :)
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
