Torque input of synchronous machine
The discussion focuses on the concept of torque in synchronous machines, particularly the balance between applied torque from the prime mover and the electrical counter torque at synchronous speed. It clarifies that under stable operation, these torques reach equilibrium, preventing acceleration or deceleration of the machine. Changes in driving torque necessitate a new equilibrium to maintain synchronization; otherwise, the machine risks falling out of sync. The conversation also touches on the fixed speed of the machine, dictated by the grid frequency, and the importance of understanding torque differences for simulating synchronous generator behavior during disturbances. Overall, the participants emphasize the significance of torque dynamics in maintaining stability in synchronous machines.
FOIWATER
I am reading from grainger about transient stability.
I know this will be a amateur question, but...
It says that when a prime mover is turning a synchronous machine, there is a equal and opposite counter torque (electrical counter torque) when the machine rotates at synchronous speed.
This is odd to me, as I would expect an equal and opposite counter torque to stall the machine.
I think he is just stating the obvious. That, under stable operation, an equilibrium exists where the applied torque is exactly countered by an equal and opposite electrical torque. (If this weren't so, then the rotor would tend to accelerate or decelerate, until an equilibrium becomes established.)
If the driving torque changes to a new level, then a new equilibrium point must be established such that the new electrical torque exactly counters the new driving torque. (If this new equilibrium can't be established within certain parameters, then, yes, it will fall out of sync.)
It should be clearer if you think of the generator as being "directly" connected into the power network, alongside many others, so that the prime mover torque alone determines whether this machine is generating or motoring.
stall? Thought experiment :: as N O said, equal and opposite means there's none left over to accelerate or decelerate the machine's rotating mass.
So ω stays constant , presumably at ωsynchronous
got it thanks guys.
This was what I assumed of course, a torque difference tends to change accln to a new steady state speed, but I was having trouble trying to understand that for some reason.
Well, it won't change to a new speed because its speed is fixed by the frequency of the grid it is directly connected into. What can change is its angle of operation, relative to the rotating field, and as this changes so does its developed torque (it obviously draws more current in doing so). The angle can only slip back so far, though, otherwise it will fall out of sync. There is a limit to everything. :smile:
Yeah I was referring to torque difference in general. What you are saying makes sense, the reason I asked the question is because I am writing a program that simulates synch. generator swing angles for large disturbances. We are finding critical breaker trip times to limit loss of synch. I have written and tested the program vs IEEE standard buses (14,30) and AEP standards (57,118) and it's working. There was just some issues with the torque that I was wanting to understand better.
Thanks
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
