Parametric equations for roots
To plot the roots of the cubic equation (7+b^2)x^3+(6-b)x^2+9x-6=0 against a real number 'b' on the x-axis, parametric equations can be derived. The discussion suggests plotting the specific case when b=1 to visualize the relationship between 'b' and the roots. Participants express interest in whether polynomial roots can generally be expressed as functions of their coefficients. A suggestion is made to graph the curves for better understanding and to encourage further commentary on the topic. The exploration of polynomial roots as functions of coefficients remains a central theme in the discussion.
Big-Daddy
Can I write the parametric equations for the graphs in the following case:
on the x-axis, I want to plot a real number 'b'. On the y-axis, I want to plot the roots (all real roots) for x of the equation (7+b2)x3+(6-b)x2+9x-6=0. e.g. when b=1, I plot 1 on the x-axis and x=0.46124674 (the real root of the equation 8x^3+5x^2+9x-6=0) on the y-axis.
(I chose the coefficients on the cubic pretty much arbitrarily but I want to see how it's done.)
Mathematics news on Phys.org
I suggest that you plot a graph of the curves involved in that example and post it. Maybe that will inspire someone to comment on the general situation.
I'm guessing that your are interested in the general question of whether the roots of a polynomial equation can be expressed as functions of the coefficients of the equation.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
