Question about voltage in a battery
  • Thread starter Thread starter jaredvert
    Battery Voltage
A battery's voltage indicates the difference in electric potential between its terminals, with higher voltage resulting in greater energy transfer to a test charge. A 3.0 volt battery will produce more current than a 1.5 volt battery in the same circuit, leading to increased power output. Higher voltage accelerates electrons to higher drift velocities, causing more collisions with particles, which generates additional heat. However, the drift velocity is minimal compared to random electron movements, meaning the frequency of collisions remains largely unchanged. Ultimately, the energy gained by electrons from the electric field increases with voltage, affecting kinetic energy between collisions.
jaredvert
Does say a 1.5 volt voltage in a battery mean the change in electric potential as one electron goes from the negative terminus to the positive terminus? Does a larger voltage battery simply mean more kinetic energy through the load (hence more friction/heat)? Or does it have to do with something else? Thanks
Voltage itself is the difference in electric potential between two points. A higher voltage means a larger difference between those two points. If we put a test charge at one of these points, the higher voltage will cause the test charge to accelerate faster and have more energy when it reaches the 2nd point.
In a real circuit, a battery at 3.0 volts will cause more current to flow than a 1.5 volt battery will, as long as the resistance of the circuit doesn't change. The 3.0 volt battery has the potential to put out more power than the 1.5 volt battery.
For example, if we have a circuit with a resistive load of 30 ohms, then the 1.5 volt battery will cause 50 milliamps of current to flow and the load will consume 75 milliwatts of power.
In the same circuit, the 3.0 volt battery will cause 100 milliamps of current to flow and the load will consume 300 milliwatts of power.
As Drakkith said, more voltage accelerates the electrons to higher velocities (drift velocities to be precise), which means more collisions with the constituent particles and thus more heat dissipation.
Because the drift velocity is so small compared to the random movements of the electrons, the number of collisions doesn't change significantly. The amount of energy that the electrons pick up from the field between collisions does.
You mean the change in K.E between two successive collisions?
Yes, I did mean that.
