Direction of Photo Electron Emission
Leb
I was looking for information on how the photo electrons are emitted when under X-ray radiation. In this ancient review paper here http://journals.aps.org/pr/pdf/10.1103/PhysRev.30.488 they state that the most common angles for non polarized X-ray beams (of various energies) range roughly at around 70-80 degrees with the beam. It is unclear to me, whether the photo electrons are moving towards the source of the X-ray beam or away from it ? Undergrad texts do not seem to shed light on this matter, the best one gets is pictures with emitted electrons being at a 90 degree angle to the incoming photon. Also, I assume this angle is given for a cone, i.e. it's 70-80 w.r.t. the beam, but with 2pi angle around the beam ?
Debends upon whether the beam is incident from the front or the back. I've done a lot of photo-electron generation, mostly in transmission.
The energy reqired to emit an electron is the "work function", which varies with the crystal plane that is encountered: 111, 210, etc. Each has a slightly different work function.
But the liberated electron may shoot off in any most any direction, though there are statistics (which I don't recall the details at the moment; they are in my old notes).
Most interactions don't make it out because of (a) going in a bad direction, or (b) scattering. Thus only interactions within a skin depth might be productive, and even then not many.
If there is an extraction field, the electron paths get straightened out.
Well, that "any direction" answers seems to conflict with experiments from 1920-30's, I wonder why did they find a preferential angle...
M Quack said:
There is actually some information that can be extracted from the direction of emission. The technique is called
ARPES (angle-resolved photo-emission spectroscopy)
http://en.wikipedia.org/wiki/Angle-resolved_photoemission_spectroscopy
http://arxiv.org/abs/1303.1438
Since I had done ARPES, I can comment on this.
The OP asked about x-ray photoemission, which is distinctly different than the "standard" ARPES experiment that is done in the UV range.
Secondly, in ARPES, the preferred direction of emission is due to the in-plane momentum of the electrons in the surface, i.e. the "k" in band structure. However, this also means that one must perform the experiment on single-crystal material. A polycrystalline or amorphous crystal will not have such directional emission and all you'll get is a momentum-averaged density of states.
I have not looked at the OP's reference, and thus, don't know if there's something similar here. XPS has other factors involved, and any preferential direction of photoelectron emission can be due to other reasons than what I stated here. Certainly, it could be angle-resolved XPS, which would have the same explanation as what I've given above.
Zz.
I have a question similar to the original post here. I can't find much information on the direction/momentum and polarization of photo electrons emitted by X-rays. Does anyone know of any good, modern, free references for this? So far the newer references I've found gloss over this topic with one sentence like "electrons scatter mostly in the direction of the E-field of linearly polarized incident X-rays," but I'm interested in learning more details about this.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
