Laplace analysis of simple LC tank (no resistance)
The discussion revolves around the challenges of using Laplace transforms to analyze a simple LC tank circuit without resistance. The user is confused about the correct sign of the voltage across the capacitor when the circuit switches from charging to discharging. They correctly derive the current but struggle with obtaining the voltage directly, leading to an incorrect transfer function. A suggestion is made to redraw the circuit, focusing on the current direction and voltage relationships, which helps clarify the mistake. Ultimately, the user acknowledges the error and expresses relief at resolving the confusion.
jrive
I am stumped by an exercise in using Laplace transforms to analyze the voltage and current in simple LC tank. My issue is with the correct sign of the voltage across the capacitor ...let me pose the problem.
A circuit consists of a voltage source V, 2 switches, a cap C and an inductor L. The switch from the source to the cap has been on for a long time (cap is fully charged), while the switch connecting the cap to the inductor is open. Then at time t(0+), the switches toggle, and the voltage source is disconnected and the cap is now connected to the inductor.
v(0-)=V,
il(0-)=0,
The laplace circuit models are:
Cap:
i(t)=Cdv(t)/dt
I(s)=CsV(s)-Cv(0-)
V(s)=I(s)/sC+ v(0-)/S
Ind.
v(t)=Ldi(t)/dt
V(s)=LsI(s)-Li(0-)
I(s)=V(s)/sL+i(0-)/s
So...I can get the answer for the current fairly easily...Since the current into the cap is defined as positive when the switch from the source to the cap is on , then when the current flows from the cap to the inductor at t(0+), it is negative, or -Ic. So,
-Ic=IL
Cv(0-)-CsV(s)=V(s)/sL
solving for V(s),
V(s)=Cv(0-)sL/(s^2LC+1)
invLaplace(V(s))=V cos[t/sqrt(LC)] --> this is fine...
my problem is when I try to solve for the voltage directly...(keep in mind that if I obtain voltage by using this current across the cap or inductor, I do get the correct answer, but not when I try to do it directly), I have a sign problem that I can't figure out...
Since the voltage across the cap = the voltage across the inductor at time t(0+), then
I(s)/sC+v(0-)/s=LsI(s) (i(0-)==0)
this is the problem...the sign is incorrect, and this will lead to a transfer function where I have s^2LC - 1 in the denominator, and not s^2LC + 1 to get an oscillatory response. What am I missing here?
The cap model during the charging phase is as shown in figure in file cap_t(0-).bmp...and for the math to work, I need to change it to the model in figure cap_t(0+).bmp at t(0+). I just can't convince myself as to why...
Hi. You're a bit long-winded, but I think I get the gist of your angst. :wink:
You say the sign is wrong, and I agree that it's wrong...so fix it!
Have you drawn the circuit of a capacitor parallel with an inductor? And marked in the current? And written the voltage across each element in terms of that current direction you drew?
Try it again. :smile:
Thanks for the response (and the criticism)...
jrive said:
Thanks for the response ...
So you discovered what you'd been doing wrong?
Yep...stupid mistake!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
