Calculate Moment of Inertia for Clock Pendulum
To calculate the moment of inertia for a clock pendulum consisting of a thin rod and a cylinder, the total moment of inertia is the sum of the individual moments for both components. The moment of inertia for the rod about one end is given by I = (mL^2)/3, while the cylinder's moment requires consideration of its axis of rotation, which is not through its center. The parallel axis theorem may be necessary to adjust the cylinder's moment of inertia accordingly. Understanding the distinction between solid and hollow cylinders is crucial for accurate calculations. Proper application of Steiner's Theorem and the correct formulas will yield the desired results for both the moment of inertia and the radius of gyration.
moo5003
Question:
A clock pendulum is an assembly of a very thing 700g rigid rod and a cylinder. The cylinder is 20cm in diameter and has a mass of 3kg. The rod is 70cm long.
A) Find the moment of inertia for the pendulum about the axis passing through the top end of the rod perpendicurlarly to the facet of the cylinder;
b) Calculate the radius of gyration for the pendulum.
O
Picture presented above.
A) I = Irod + Icylinder
Irod = (mL^2)/3 + ?
I'm not sure how to get the second one, infact I was confused how they got (ml^2)/3... I can only get (mL^2)/4 when I take the center of mass and treat it as a particle. CM: l/2 to mR^2 to m(l/2)^2 to (mL^2)/4
ANY HELP IS GREATLY APPRECIATED.
So are you asking for the moment of inertia of a cylinder ?
Check THIS
Be sure that you know whether the cylinder is solid or not.
marlon
EDIT : you will also need to apply Steiner's Theorem, so make sure you know about what axis you are rotating. This is also important for getting the right I-value for the rod and the cylinder
You can't find the moment of inertia of an extended body by treating it as if its mass were at its CM! What's the moment of inertia of a thin rod about one end? (Look it up or derive the formula.)
The total moment of inertia is the sum of I(rod) + I(cylinder). When figuring out I(cylinder), be sure to consider that the axis of rotation is not through its center.
Also if I may add, you may be looking to use the parallel axis theorem after looking up the tables.
