=Homework Problem: Longest Vertical Soda Straw
The homework problem focuses on determining the maximum height of a vertical soda straw that can be used for drinking. Key concepts include understanding atmospheric pressure, cohesive and adhesive forces, and the mechanics of sucking liquid through a straw. It's important to realize that when sipping, the liquid is pushed up by atmospheric pressure rather than being pulled. Clarification on the question's intent is needed for better guidance. Overall, grasping these principles will help in solving the problem effectively.
Gott_ist_tot
I received a homework problem that I need guidance on where to start.
What is the longest vertical soda straw you could possibly drink from?
I do not know where to start on this problem. A small push in the right direction would be greatly appreciated.
Can you please specify your doubt a bit more. I didn't understand what the question means?
Probably something to do with cohesive and adhesive forces? or over coming gravity by the force exerted by the sipping the straw
Think about what's actually happening when you suck.
You're not so much pulling liquid up the tube as much as allowing atmospheric pressure to push it up.
Oh, and please don't repeat your questions. I've just seen that you had a good answer given just a few hours ago, the first time you asked.
