Amedeo Avogadro & Molar Ratios: Gases, Solids & Solutions
Molar ratios can be applied to gases, solids, and aqueous solutions in chemical equations, allowing for consistent stoichiometric calculations across different states of matter. In the reaction Mg(s) + 2 HCl(aq) -> MgCl2(aq) + H2(g), a 1:1 molar ratio exists between magnesium and hydrogen gas. Therefore, if two moles of magnesium react, two moles of hydrogen gas will be produced. This concept is linked to Amedeo Avogadro's hypothesis, which states that equal volumes of gases at the same temperature and pressure contain an equal number of molecules. The coefficients in a balanced chemical equation represent the molar ratios of reactants and products, applicable to moles, atoms, or molecules.
Mozart
Can I use molar ratios for gasses, solids, and aqueous solutions all in one equation?
For instance: Mg(s) + 2 HCL(aq) -> MgCl2(aq) + H2(g)
Can I say that if i had 2 moles of Mg I would have 2 moles of H2. Does this trick have anything to do with Amedeo Avogadro?
Chemistry news on Phys.org
Yes, you can do that.
In the reaction you gave,
You can see that there is a 1:1 ratio for every mole of Mg reacted to Hydrogen gas produced. So if two moles of Mg were to react, 2 moles of H2 would be produced.
Thanks man.
Does this have anything to do with Avogadro's hypothesis?
The coeffients in the reaction are meant to show the ratio of each substance being reacted/produced.
The coeffients could mean the number of moles but they could also mean the number of individual atoms/molecules too.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
